jmatteo1
- Joined
- Apr 9, 2005
- 85
I'm in the process of getting a '78 Wellcraft with a Mercruiser 898 in it going after 2 years of storage (see Clicking not starting) Anyway I got it started with muffs on but she wasn't spitting out any water. recehcked the oil and plugs, no water there. Took off the lower unit. The impeller was slightly damaged, so I replaced it, same results, no water coming out. I checked the intake for a blockage and found nothing. Am I correct in thinking that the impeller should be taking in water at an idle with the muffs on? Also, I took off a hose from the port side of the thermostat housing and ran water in slowly. It came out of the exhaust as it should, and it also circulated back around and came out of the thermostat housing where I took off the hose. Any suggestions would be greatly appreciated.
