Impeller ?
sphelps
I need to order a new impeller for my 85 Force . Iboats has the Mallory and Sierra listed . Other than a buck or two difference is one better than the other ? I have never changed one so this will be a learning experience for me .:facepalm::)
Frank Acampora
Re: Impeller ?
They are probably made by the same manufacturer. Buy whichever one you want to.
sphelps
Re: Impeller ?
Thanks Frank ! I bought an impeller but it did not come with the gasket that goes under the metal plate . This was mentioned in your sticky at the top of the forum page . Is this a must change step ? I guess I should pick one up .
BTW ,your little tunnel hull video was awesome ! That thing will scoot !
jerryjerry05
Re: Impeller ?
If you didn't remove the gasket and it's complete.You won't need to replace.
