Re: impeller
I just replaced my water pump on my 58 evinrude, and I am sure its the same sequence or setup<br /><br />You have shift linkage that goes along the bottom shaft all the way to the propellar. All the gears are down there. There is a rectangle with rounded corners with two screws in it on the side of the long piece between the motor and the propellar. The long piece is called the exhaust housing. The rounded rectangle is on the exhaust housing. Inside this cover is two bolts, I forget the size 7/16" I believe or one size smaller. loosen the bottom bolt. <br /><br />Now there is 4 bolts above the propeller that you will need to remove with a 7/16" socket, and a large bolt that you will need to remove with a 9/16 socket. The 4 bolts are facing downwards to the ground, the larg bolt the head is facing towards the motor.<br /><br />once those are removed, now you can pull out the lower unit. There is 3 screws holding the water pump housing on the drive shaft(the longest shaft). Your impeller is in there. Remove it, clean the inside of the housing and put your new one in. Assemble the lower unit in the reverse.<br /><br />I would recommend a manual for your motor. It is a pain in the butt to get the lower unit back on you need to line up the water tube, gear linkage, and the drive shaft to get in correctly. It would be wise to have someone helping you out.
