i recently replaced the impeller on my rde-17 johnson. the old impeller was in shreads when i removed it. i figured it was turning clockwise so i bent the tips to the left. will the tips self align after it runs or do they have to be installed a certain way. i started the motor with water above the inlets but only let it run for about 5 sec. i did not see any water come out of the water outlet. did i not let the motor run long enough or is the impeller in backwards.thanks for your help. john
