Hello,
Working to get this old motor back to snuff, compression good, new plugs and wires, cleaned up cap and rotor, dropped the lower unit-impellor is ugly, only one complete vane left. My question is, how do you get the last of the debris out of the lower unit, there are a few small chunks of rubber down by the water pick up holes. Is there any trick? Where else do I need to look for obstructions? We ran the motor 3 or 4 minutes to check it out in the lake, had good pressure out of the pee hole and the water was hot by the time we were done. Should I have any concern, again, compressions were good, 120-125 on all. Welcome any suggestions
