Impulse/Uniden depth gauge
nitsuj
Hello all. My houseboat has a Impulse QT206 depth gauge. It would appear the same gauge was also sold under the Uniden name, and it would also appear that neither brand still makes my gauge. Would anyone happen to know if there is a gauge that can be wired up to the existing transducer so I can just replace the gauge and not have to screw around with wiring and installing a new transducer? (I don’t mind cutting a bigger hole for the gauge if need be) It’s a 200 MHz unit, apparently, if that matters.
Thanks!
dingbat
Thanks!
Transducers are consumables. The chances of it working are pretty small.
Not to mention transducer connectors are not standardized between vendors. Matching a head to the transducer would tough.
Easier and less risk to just replace the unit in its entirety
