I have a 90hp OMC quietrider and need some advice other than throw it away. It currently has 17 pitch prop, new coil packs, plugs and wires and been decarbed and cylinders cleaned. compression is 130,110,125,and 115. Maxes out at 4500 RPM's with light load. In addition the lower two plugs are always a little wet and the top two dry. The strangest part is after cleaning out the cylinders and running on the lake, it achieved 5200 RPM's for a short time. Could this be due to the extra combustible chemicals in the chamber, moisture on the rings. Where do I start? In addition, raising the engne I don't believe is an option on this lizard.
