Jfleck01
- Joined
- Nov 8, 2023
- 2
I’m working on a 1995 Four Winns 240 Horizon with a 5.8 liter Mercruiser engine. It has the OMC Cobra out drive (I believe it might be the SX). I need a bellows kit (exhaust, drive shaft, and o-rings). I also need both exhaust flappers (which would include the pins and grommets).
The outdrive serial # is T0790869 … PROD # is 3868158. (images attached)
Drive shaft bellow # is 3854127 (embossed on the bellow - image attached)
Exhaust bellow # is J-18332 - ? (Embossed on the bellow - image attached). Note: I put a question mark after the second dash because the hose clamp has distorted anything following it…
Other stuff -n- things..
The water intake pump impeller disintegrated and overheated the engine - which I replaced (and changed out the thermostat as well).
The flappers melted and fell to the bottom of the exhaust Y tube. I’m assuming this occurred when it overheated…
The boat is taking on a lot of water since then (the bilge pump kicks on every minute or so…).
I noticed that the drive shaft bellow had a lot of water in it when I removed it - but I could only find a very tiny tear/hole in it. Could either (or both) of these be causing/contributing to the boat taking on the water ?
I very much appreciate any feedback you can provide - and Thank you in advance !!!
