Foxfire180t
- Joined
- May 11, 2014
- 4
In reference to this thread, http://forums.iboats.com/mercury-ma...ew-stalls-idle-1988-mercury-35-hp-483927.htmlThat looks like the idle stop screw that advances or retards the idle but unless you've altered the timing I wouldn't move it. Instead, adjust the low speed screw in the carb at 800-1000 while engine is running in gear.
Would you happen to know where the low speed needle is located? Which one is it? I actually have the 115tower of power same issue. Idles great out of water hooked to hose but once in water will idle occasionally as soon as put into gear it dies. But going into gear immediately almost wot it picks up and runs immaculate. Planes almost immediately and runs about 5200 wot.. help!!
