After reading a bunch of posts I am suspecting something in the fuel tank. Whenever I try and put gas in the tank I can get 2-3 gallons in and then it tries to come back out of the filler neck. leaving it sit a while in the sun and trying to open the gas cap relases alot of pressure plus gas tries to come out. I also verified I only have a half a tank of gas. The vent hose is clear although it did have some fuel in it when I blew it out.
Taking everything out of the tank I noticed the vent line in the tank is nylon and measures about 40" long. I'm not sure how or why it has such a long pick up tube. it is alot longer than my fuel tank. It also has a kink so I suspect that may be the culprit. Can I cut the pick up tube back a bit, maybe in half?
Do you think this is the culprit for the boat not running right after it's been in the water for a while and the reason I can hardly put gas in it? Thanks for your help.
