Re: Inaccurate Tach
Sorento25, The tach in your boat runs off the negative side of the ignition coil. The usual reason for inaccurate readings is bad connections to the sender, battery or ground, or a bad tach. Since yours is intermittent, it is likely a bad connection.
I have an '88 19 foot Sorrento, and have the same issue. The tach will read at least 1000RPM too high at cruising speed. it has been like that for many weeks, and I was to lazy to fix it. However, last week when I left the dock, the tach read high, when I returned it read accurately. Go figure.
Airxsteel, Outboard tachometers run off the alternator pulses. I am not too familar with Johnson motors, but an owners manual or shop manual should show you where to hook up the tach. You need to set it for the correct number of pulses (look for a "J/E" setting on the back of the unit), an connect it to battery, ground and the sender (alternator wire).
