Inboard Chevy misses at low rpm
mapss
A friend has a boat with inboard dual small block Chevy’s. The 1 with a problem has about 1700 hours on it, mainly trolling (800rpm), since a rebuild. Distributor is point type with electronic conversion (brand is not known yet). <br />His Initial indication of a problem was a miss at low RPM, which smoothed out as RPM increased. He said he had a problem similar to this that was the distributor and was replaced a couple hundred hours ago.<br />His trials:<br />Switched carburetors with other engine.<br />Change back to points.<br />(Somewhere in this process noticed the timing had changed but distributor inspection indicated chain is tight)<br />Turned distributor 180deg.<br />Switched plug wires 1 position.<br />Present condition (his observation):<br />It misses but under low RPM, under load makes a lot of noise. Higher RPM smoothes out.<br />Starter does not have as much power and thought he heard it stay engaged after engine was running.<br />He called me because he thought it was all related to an electrical problem because even the gauges for this engine have been erratic. Fuel tank is full at ¾, tack jumps, etc.<br /><br />Present plan of attack:<br />He is going to have starter checked or a replacement.<br />I’m going up this weekend and try set all back to original condition (start from the beginning).<br />Check grounds, load, alternator output and general electrical.<br />Check coil, electronic pickup and monitor for miss.<br />Check vacuum for valve condition etc.<br />Switch distributor with other engine if all else fails after checking for physical damage and or taking a known good Delco automotive distributor for testing. <br /><br />Here are my questions:<br />Has any one had a similar problem?<br />Have I overlooked something?<br />Will the automotive Delco work as a permanent replacement (enclosed compartment fresh water 30+foot cabin type fishing boat)?
rbezdon
Re: Inboard Chevy misses at low rpm
Looks like you have covered most of the bases. I would consider bringing a new set of plugs and a compression tester. The answer to the last question is NO!!. The main differences in marine vs. automotive are electrical and fuel. The whole idea is that the flammable vapors inside the engine compartment can be ignited by any arcing so all marine parts have a different design to minimize this possibility and all of the fuel components have designs to minimize the potential for allowing flammable liquids or vapors to enter the engine compartment especially in the event of a problem (such as boat inversion). I think the Delco would be OK for a short test, just make sure the engine compartment is WELL VENTILATED during your test.
mapss
Thanks <br />I did not think of flammable vapors. I was only thinking of water.<br />Swamped my truck one time and was impressed with the Delco staying dry but caused other problems so I decided to use a boat next time.
rbezdon
good decision. I think you'll find one unanimous opinion from everyone on this site that a boat works much better in water than a truck. (Although I have been at a few boat ramps where some have tried to dispute this!!
