Re: Inboard/outboard change to outboard
Didn't mean to start an argument, but I just assume that everyone fishes. Yes, the I/O is quieter, but it's much heavier/HP. And annual maintenance is generally more costly. OB? change plugs & lower unit grease: done. OB? Big motors generally require a 2nd trolling motor, while I/O can usually get away with a prop baffle (I/Os can idle away all day, while my OB clogs up in an hour). Carb OBs seem to go on forever with little maintenance, while I/Os, seem to have more "issues." <br />But the main reason I prefer OB is that all things being equal, an OB has lots more room in the cockpit....which we then fill up with icechests, chairs, tackle boxes, bait boxes, anchor lines, etc.....!!<br />Hey, if you're fishing it doesn't matter what you're driving...
