Re: inboard power or outboard power
If all you are concerned about is acceleration, top speed and maintenance, I absolutely vote outboard. The fact is that the best horsepower to weight ratio product will have the best performance for the same bhp if it is correctly rated at the same place (propshaft) on identical hulls. The lightest combo today on the higher ratings are two cycles, but the 4 cycles are pretty close; within around 100 lbs. They argue a lot about maintenance in the OB Sections above between the 4 Cycles and the 2 Cycles, but the combination of an outdrive and an automotive engine is probably the worst. True inboards are decent on maintenance, but have the slowest top speed numbers by a lot. Diesel will be the worst performer, but best on fuel.<br /><br />Again, if you are comparing equal horsepower at the prop-shaft, the OBs are gonna be fastest. If the option is a 225 I/O vs. a 175 OB it will be a close race on top speed. with an edge possibly going to the I/O. If it is a straight inboard or v-drive, the OB will win in a race.
