joe_classic
- Joined
- Mar 12, 2010
- 12
Hi all, soem of the other members are helping me with purchase of a 40HP 3 cyl Tohatsu but I had not mentioned why I was repowering.
Heres the drum - I currently have a 30HP 2008 2 stroke Tohatsu on a Zodiac (Alum floor) Mk2C (3.8 metre) Futura Hull with forward controls and a light seat and steering frame.
I am having trouble with the boat reaching quick planning with 2 up failrly heavy crew at 90kg each - no we can't loose weight just now)
If I add a bimini top with light winds the situation is hopeless.
Boat is rated for max 40HP and 95kg engine weight so the Tohatsu just gets in at about 87kg. With the 30HP I have tried one prop pitch down from standard, changed weight distribution, motor heights and trim but it still struggles. Most noticeably it dies in tight turns. BTW - I had this Tohatsu from new so don't suspect engine problems.
I am thinking of repowering with a 40HP Tohatsu 3 cyl (40D). I suspect the 30HP is OK once she is spinning fast and on plane but because of its relatively small block I suspect it just doesn't have the torque and block size for easy hole shot and am guessing the 40D with around 700 cc block size should substantially help. I previously had a 1995 25HP evinrude which had much better hole shot.
Does anyone have experince with this boat and a 4oHP Tohatsu or other. The other problem is the transom is for short shaft and the secand hand motor is 20 inch Long shaft. The next Zodiac up (Mk2 4.2m) has a long shaft spec and the transom appears to be identivcalk except does not have a deep cutout as my boat has on the transom. I can easily biuld up the transom by filling in what Zodia cut out of my transom.
The other advantage is I get elec trim and tilt on the 40HP meaning I never have tpo leave my seat on launcg or to correct trim.
Any thoughts on this whole madness of mine.
Thanks again for your answers
