Re: Increasing carb jets
If the motor was running correctly before the rebuild, it is really not necessary to increase jet sizes just because the cylinders were bored out. With that said, it is common to increase the size of the high speed fuel jets after a rebuild just to assure that the engine won't run to lean, especially on older models that were built before crappy gas hit the market. If you want, increase your jet size by two sizes. For example, if you had 36's go to 38's. Also retard engine timing by 2 deg from factory spec. Before you do this you really need to know why did the engine fail, and then, has that cause been corrected?
