Had the little 60 hp on the water muffs after some speckled trout chasing and had a surprising thing happen. After cranking on muffs and letting run for approx. 3-4 minutes at normal idle (when on muffs) at about 1000-1050 rpms(normal when on muffs), the motor had a increase in rpms of about 100. Then I heard it increase again at about the same increment. After probable 30-45 sec., and an increase to 1400 rpms, I went up and shut it off. Anyone heard of this phenomenom before? I read on a search about runaway engines while on mufs because of carbon buildup. Does this sound like the same thing except not quite hot enough to "runaway"? Any help is appreciated.
