- Joined
- Mar 8, 2009
- 43,317
Friends Malibu ski boat with a Indmar 383 and MEFI-5 is throwing code 66017 (Fuel Pump Relay 1 Voltage Below Normal or Shorted Low). The engine starts but will not allow it to rev more then about 1400 rpm or so. It has 3 relays, main power, Fuel pump and don't know what the third is used for.
It all started after he had issues with low battery which set codes for all his injectors. Replaced batteries and erased all codes and this one keeps coming back up. I downloaded the service manual and have yet to start the testing procedure, but could sure use a wiring diagram.
Swapped the 3 relays around all which ways, and remove/re-installed the connectors on the ECM. Was hoping for a bad connection, but no help. Anyone know where to get a wiring diagram or seen this fault code before?
