Indmar 5.7 vortec will not start
Z3cta
Hello guys....I am in need of help and suggestions
I have an 07 Indmar 350 MCX engine (chevy 5.7 vortec MPI) in my Mastercraft which ran fine and I was about to launch it and it quit running and not will not start. It cranks but no start. It tries to run for a few seconds and then it dies out. I try to give it gas in neutral but that does not do much and it tends to backfire a bit and then turns off. I made a few recordings while trying to start it and when it sputters and backfires for review. Any ideas will appreciate it. Thank you
https://drive.google.com/file/d/1L3D0ZyhUQ_BDH_p2gc3rRqsw942yCtiZ/view?usp=sharing
https://drive.google.com/file/d/1J3IEbfiJbnZoVUlY4uI4H-R3_VB4KCPS/view?usp=sharing
https://drive.google.com/file/d/1A7uPZDoss7ki2jaxwZHC7ydBWFXeIGOv/view?usp=sharing
I'm not downloading a file to watch
Check fuel pressure and if there is spark
I have 6 Indmar manuals but don't know which one would be used for your motor. Have to cover MEFI 1 thru MEFI 6
The MEFI 6 list 55 to 62 psi
Having fuel and spark means it should run but something is not staying on. Need to scan for codes
Z3cta
Bad fuel, bad pump, fixed that, it runs now, but I am getting a misfire on cyl 2 and not go over 3k rpm
...ugh...boats
Antax
with the bad fuel you could have a clogged injector now. Or possibly a fowled spark plug. I would start with changing the plugs and if it doesn't get any better pour a bottle of sea foam in the tank and run it.
