daveski1964
- Joined
- Mar 20, 2014
- 39
I have a 1986 85 hp force motor ,,carbs need rebuild ,I check compression have 100lbs in top two cylinders and 90lbs in bottom cylinder,,my question, is that enough compression to get thru this fishing season and I could rebuild motor over winter??I was going to rebuild carbs and see if boat would make it thru this fishing season......should I press my luck or no....just rebuild now???
