Injectors 3,4,5 and 6 not firing 4.3 MPI
wpowell323
I have a 2006 model 4.3 mpi with an alpha, I have the motor out of the boat to replace the head gasket, all the work is done and it is back together. The motor will spin over, but not start. I tested it with the DDT and when doing an injector test injectors 3,4,5 and 6 are not firing. I can switch leads from injectors 1 and 2 to the other injectors and they will fire, so I don't think it is an injector problem and i have have good fuel pressure at the rail. The motor was running before i removed it. I am thinking I have a sensor plugged in wrorng or am just missing something stupid, any help would be greatly appreciated. Serial number is OW634777
Fun Times
Re: Injectors 3,4,5 and 6 not firing 4.3 MPI
That is normal.
Your injetors only fire on two banks, the rest would be for if you had a sequential multiport fuel injection system, you do not.
Your two wiring colors should be LT GRN/PPL & LT GRN/WHT with PNK/WHT going to the fuse holder?
Cylinder/Injectors 2,4,6 should be LT GRN/WHT
Cylinder/Injectors 1,3,5 should be LT GRN/PPL
Do you have spark?
