Sangster21
- Joined
- Mar 15, 2012
- 130
I am going to start a new thread on this issue as I believe I have had some other issues that have been confounding this one. I have a recently rebuilt (bored 0.030" over, new pistons, cam, bearings, head done etc ) chev inline 6 250 cu in mercruiser 165, and am having an issue that is making me pull my hair out. The engine is set up with a heat exchanger, the only raw water is thru the heat exchanger and out thru the exhaust riser.
I am going through coolant and having blowby with a fair bit of steam coming from the crankcase vent. I tasted the liquid that built up on the spark arrestor and it tasted sweet which certainly indicates to me that it is coolant not seawater that is causing it.
When I checked the dipstick there was some signs of milky oil water mix, but only high on the dipstick. The oil when checked shows clear and no contamination by water. The oil fill cap shows signs of oil/water contamination ( milky skudge), but the coolant pressure cap does not, nor does the coolant appear to be contaminated.
My intake manifold is near new, I pressure tested it with block off plates and air, it is not leaking.
I checked my riser for leak ( with solvent) and replaced the block off plate ( old one looked pitted and crappy so I made a nice new one) and installed new graphite gaskets. When I pressure tested the manifold I had the riser in place ..... no leaky.
I have been chasing this issue for quite some time now, I have removed the head and had it checked (magnaflux and pressure) and apparently it is fine. The problem definitely gets worse as engine gets hot. Last time I had it out I ran for about 30 minutes and saw some vapor skudge appearing below the spark arrester....... fished for a bit, then ran home for maybe 40 minutes and it looked like a bit of a steam disaster under the dog house. The problem appears to worsen after a good run.
If I am getting water into the combustion chamber ( this seems like the cause as it shows itself as blow by) I can only deduce it is coming from the manifold or from the cylinder head??!!
What is my next step, pull the head again and have the shop go over it with a fine tooth comb? Haaalp.
Regards,
Alan
Regards,
Alan
