ShowMeGuy
- Joined
- Jan 31, 2012
- 560
I've pulled the motor out of my old Tin boat, the outdrive and the bellhousing & bellows. Now, all that is left is the stuff that is hanging or bolted down or to the Inner transom plate. Like say the trim pump and it's hoses.
1st the trim pump. Where should I remove the hydraulic hoses? the lift cylinders and let them drain out to a pan? then pull them and the trim pump out?
Can anyone out there give a guy some advice as to what to remove first and 2, 3rd etc?
I'd much appreciate the advice and hope to get it removed tonight after work if I can. Then remove the rotton transom plywood.....
TIA!
TIA!
