inner transom plate
vxtech
will a 70's- 80's 470 model transom plate(mercruiser) work with mercruiser inline 6 gimbal &outdrive or does inline 6 have its own design inner transom plate?
Bt Doctur
Re: inner transom plate
has more to do with the width of the rear mounting bolts.
early were 12 ish and later are 9 ish.
vxtech
so what your telling me is as long as my bolt holes match width wise with the 4 cyl plate i can be use it with 6 cyl set up right ? also do you mean holes thru transom for gimbal or where bellhousing bolts are vertical to mate engine?
Ayuh,...
BD is talking about the Rear Motor Mount spacing....
