Inside Motor wash
Nandy
So, if you buy a motor that was used in salt water and want to clean the water jacket what will you use? Is this something that is regularly done? I can take the motor apart and clean every part of the water jacket that I have access to but I rather avoid opening a motor just for that... I did cleaned everything I could when I replaced the thermostat but wanted to clean as much as I could. I dont see myself taking this boat to salt water, so maybe the constant use in fresh water will loose up the build up? I doubt that...
tashasdaddy
Re: Inside Motor wash
salt away stops the salt, but the damage is already done. you can open it and remove scale, but probably not worth it.
Nandy
ok, that makes it simple! Thanks TD!
