I am currently restoring an old bass boat. It had been sitting in a field completely untouched for at least 4 years (and unknown how long, if any, before that). The outboard is an '87 90hp v4 crossflow (J90TLCUR). I am rebuilding the powerhead due to low compression in 2 out of 4 cylinders with some scoring.
I want to check out the lower unit to determine what needs to be done. The water pump (entire kit) for sure is getting replaced. I THINK the gears themselves are fine, but throwing this out to the group to see if there is anything I might be missing. When I cracked open the drain plugs, I was glad to see it still full of gear lube and it came out clean without any water. Not milky at all and no water after the oil. The magnet on the bottom plug was free of any metal at all.
The LU shifts between F-N-R well enough. When turning the driveshaft CW by hand, the prop shaft spins CCW in F, not at all in N (spins freely), and CW in R (I might have the F/R backward as I can't recall which-is-which with the shift lever up/down). I took a look at the propshaft seals and the seals under the water pump and they seem fine to me.
I've rebuilt a couple of LU in the past and I'm not seeing any signs of issues I had with those units so my untrained opinion is that the gears are most likely fine. Is there anything else I can do to confirm?
