Bought a used 1978 14ft aluminum boat. Motor is a 1997 25hp Tracker Merc with power trim and all the controls. Motor and controls are not attached to the boat. Motor came off a pontoon party boat and replaced by the 60hp that was on the aluminum boat I bought.
I am planning to
-change the impeller, possibly the whole water pump
-leg oil change and inspect
-carb cleaning
-overall grease and lube
-plugs
-change oil in power lift
This motor has thermostats, should I just change those also or just wait?
Main question so far: Whats the easiest way to mount this motor to the boat? couple of strong hands to hold motor up while bolting in place OR remove power trim, attach to boat, then hang motor on power trim?
Is there anything that may be troublesome with attaching this motor/controls into the boat that may not be obvious?
i have searched and read this site for weeks. Tons of valuable information and helpfull advice.
Listed at $2200, got for $1000 not being able to see motor running let alone a test drive.
I am planning to
-carb cleaning
-plugs
