Good Day,
I have a Twin Engine Boat (4.3LX's) with one (1) Fuel Tank. I do not have Water/Fuel Separator Install.
Should I install 0ne (1) Kit / Engine or One for Both Engine ?
Thanks.
AllDodge, S/N OC454332 & OC534197
I will check tomorrow (and get back) if it is a two line feed or one. I would be surprise if it is only one line !
Bt Doctur, ''plug the one filter and both engines are dead. ''
I guess there would not be enough gaz going through the 1 filter to feed both engines?
Appears you have mechanical fuel pumps which have the filter built in to the pump. The upside down filters can be a mess to change. Item 1 in the link below
http://www.mercruiserparts.com/Show...r=951&bnbr=90&bdesc=FUEL+PUMP+AND+FUEL+FILTER
Agree with BtDoc that two are better then one but also think one filter can handle both V6 engines if your feed line is a minimum of 3/8 ID.
Ayuh,..... 1 filter can handle the flow of 2 4.3s when the filter is fresh, 'n clean,.....
Add some time, crud, 'n abit of water, 1 filter could leave ya miles from shore, both motors Dead,...
1 filter each motor, anywhere easily accessable so you can change it easily,....
