Re: Installing a Carb
When you take off the old one be sure to look at all the linkage and the return spring so your familier with it when you reinstall. Also if removing old one, dont tip it too much as gas may come back all over you or the engine. Other then that, ditto to the "pretty straight forward" quote above.
PS Be sure to use a new carb to manifold gasket with NO sealant.
