Re: Installing a cooler through the floor
Put up what kind of boat it is.
The first thing that came to my mind was that you could cut through a floor support.
As long as you are absolutely certain what is under where you want to cut, i.e.foam, wires, piping,hull and are sure you aren't cutting any support members it should work.
You will need to come up with something to keep the cooler in place as you run the boat and you may have problems finding a part of the hull that is flat enough.
My best advice, be absolutely sure of what you want to do and that it will work as planned before you even start, you don't want to just start hacking on your boat.
Buddy decided to put a livewell in his front deck,grabbed his saws-all and started cutting, went through 2 deck supports, ended up redoing his entire front deck and still doesn't have a livewell, be carefull.
