jayhanig
- Joined
- Jun 27, 2010
- 836
I intend to install a pair of flush mount Perko stainless steel rod holders on my boat but am worried about screwing up the job. Every description I've read so far has suggested I use a 2" hole saw vertically and then ream it out to the appropriate 25° angle so it will lay flat on the top of the gunwale. Well, I don't have such a bit but I do have Forstner bits... bits normally used to cut circles with flat bottoms. Would that be OK for the job or should I go out and buy the hole saw bit?
I was planning on inserting a foot long piece of pressure treated 2 X 4 underneath the gunwale to use as a backplate and towards that end milled a couple of pieces to the right size and drilled the 25° hole on my drill press. My reason for all this is because I intend to use the rod holders as insertion points for a boarding handle rather than for fishing. I mentioned this to my local boat guy and he looked at me as if I was crazy. He just recommended using stainless steel #10 machine screws along with nylon lined retention nuts and fender washers.
I know I'm way overthinking this but I'm intimidated by the thought of possibly messing up the job... I can see the bit skipping and dancing over a wider area than what the flange can hide... disaster. One other thing: the underside of the flange is a little bigger than the diameter of the tubing so I had to drill using a 2 1/8" Forstner bit to get things to lay flat. With hindsight I probably should have just drilled a 2" hole all the way through the board and then made a shallow 2 1/8" hole to accommodate the underlying lip of the flange.
Even if I don't use the wood as backing plates, I suppose I could use them somehow as jigs to help me drill the proper angle by just laying them on top of the desired hole.
Any advice would be gratefully received.
