Installing a jackplate
geeco1
When I rebuilt my transom, my motor ended up about 1 inch higher than before. I don't know why, I can only suspect that the transom cap is thicker and the wood is slightly higher. I now notice that I have a little more issue with prop cavitation (or what ever), basically the prop loses grip easier. I really noticed this, on the past weekend when pulling a tube. My wife and another passenger was sitting in the bow and I kept sucking air around the prop. I had them move to the rear and the problem seemed better.
I was thinking about installing a Jack plate so I could lower my motor a couple inches. I know that I can buy commercially made ones but was wondering if I could make it myself cheaper. My idea is to take two plates similar to the picture below, and mate them up to each other and secure with 4 bolts. I don't anticipate wanting to raise/lower the engine once I get it adjusted.
If I try to make one, what thickness aluminum would be required?
Are there any cons to installing a jack plate on my boat (see signature)?
jason32038
Re: Installing a jackplate
Jack plates are crazy expensive. Making your own jack plate might be more of a headache than just trimming the top of the transom off and refinishing it.
fucawi
Banned
for an 85 HP you are going to the talking 1/4 steel plate or 1/2 ally ..waste of time trim the transom
geeco1
Trim the transom?? ugh! I was hoping to avoid that. I didn't want to have to re-seal the top of the wood, seal the old bolt holes, and make a new top cap. Oh well. Maybe I'll use it as an excuse to buy one of those dual-cut saws that I've seen.
Thanks guys.
