Installing a voltage guage
HookMaster
I have a 1984 Evinrude 100 HP V4 Commercial completely rebuilt with about 160 hrs on it. I would like to install a voltage meter on my console to be sure I am charging my battery when running. Sounds simple but just need to know how to connect it. I assume instructions are in the box but any help would be appreciated.
Thanks,
Don
Silvertip
Re: Installing a voltage guage
There are three connections on a voltmeter. 1) Light, 2) +12V when key is on, and 3) ground. Connect the light terminal to the light terminal on any of the other gauges. Connect +12V terminal to the +12V terminal on any of the other gauges (the speedometer doesn't have that connections). Connect the ground terminal to the ground terminal on any of the other gauges. If you don't have any other gauges, get you will need to make the connections at the ignition switch.
HookMaster
Thanks,
Sounds simple enough. Is this an indication of the output of the engine alternator or just a reading of the output of the voltage from the battery? If the battery is not charging what will the meter read? What is the difference between battery tester guage and a volt meter? If a battery is down to a half on the test guage, will it still read 12 volts? I might not be asking the right questions......
"I'm allergic to electricity".............(Just kidding!)
Don
Silvertip
The battery is the heart of the boats electrical system. All power used by the boats accessories is drawn from the battery. The job of the engine alternator is to replenish the current drawn from the battery. When you turn the key on but have not started the engine, the voltmeter will read battery voltage. It should read about 12.6 volts. Since the gauge is not calibrated that closesly, as long as it reads about 12 volts that's an indication the battery is charged. When you start the engine and rev it to about 1500 or so, the voltage should increase to about 13.6 - 14.5 volts give or take a little. That is the indication the battery is being charged. A voltmeter cannot tell you the "condition" of the battery other than its voltage. A battery must be "load tested" to determine if it has any bad cells. Inability to hold a charge however is a good indication that the battery is headed for "battery heaven". Such a condition would manifest itself as a very slow turning starter even after the engine was run long enough to where you know the battery should be fully charged. If you turn the key on and the voltage is 10 volts is an indication that something in the boat is operating even though the key is off, but it can also be due to a bad cell in the battery. Another way to look at this is that if the gauge reads above 13V all is ok with the charging system but is no guarantee the battery "condition" is ok. It just means it is receiving a charge. Any reading less than 13 volts with the engine running indicates the charging system is not working.
HookMaster
Silvertip,
Thanks for taking the time to enlighten me on the system and how it works. It all makes sense. I have a load tester (Portable battery test guage) that I can test the condition of the battery before and after launch. I had a problem with the battery not charging and spent $450.00 to replace the coil etc. That was why my tach was not working as I believe it runs of the charging system. Works now. Also had to replace the starter since it would not engage with a fully charged battery, only to find out it was the solenoid not working. Put in a new solenoid and starts right up. Probably needed a new starter anyway since it was 24 years old.
Will get a volt meter today and put it in.........
Thaks again,
Don
Gary H NC
Make sure to unhook the battery from the motor before doing any testing!
Any electrical wiring should be done with the battery disconnected. One little spark and the rectifier gets toasted...The joys of outboards...:D
