installing blue sea systems add a battery dual circuit system pn 7650
pitman2
i have a 1982 wellcraft bowrider 180 v6 3.8 litre.i would like to install this add a battery system but the schematics are a little confusing.
could i connect both batteries w/1 ground cable then 1 cable to the engine ground?
what size in-line fuses do i use on the 2 cables from the acr to the batteries?
what size cable should i use from starter battery to alternator?
what size cable do i use from the lower terminal on the acr to the fuse box w/what size inline fuse?
i guess i just want to know how many cables this installation takes.i plan on using #4 marine grade cable.
any help would be appreciated. any suggestions on cable size from gnd,si,and led quick connects on acr?
