JK Turtle
- Joined
- May 18, 2013
- 26
So over the winter, my manifold cracked, I was able to get it welded back up and have everything installed. When I tried to fire it up, it will try to crank but about every 4 seconds or so it sounds like it backfires and will not start. I have a Mercruiser 4.3 TKS. Unfortunately while putting the engine back together, I left the distributor cap on my bumper and drove off. :mad-new: I ordered a tune up kit that came with a new trigger wheel. So after the engine not starting, I rotated the engine to top dead center, and looked at the trigger wheel and it looks like it about to fire cylinder 3. Now I know I must of messed up somewhere. But, I know when I installed the new trigger wheel, there is only 1 direction it will fit onto the distributor shaft due to the locating key, and I know the distributor shaft will only fit into the engine in 2 directions, but I installed it at the same angle as when I removed it. Even if I did install the shaft wrong, the trigger wheel would be trying to fire cylinder 6. I've double checked the plug wires, and they are all correct, any suggestions?
