pauldjasmine
- Joined
- Sep 13, 2002
- 17
Only had boat a short time . Removed gear housing to replace impeller on water pump Now I am having a problem shifting gear box to forward gear and pushing it back up into leg. The shift rod seems to turn only one way but after installed it dosen't shift into neutral or another gear. Should the shifting rod turn to make prop turn in both directions? Does it need a little force? Thanks
