I have a Mec. 9.8 1965. I had to remove the exhaust plate because it was plugged and the motor would not pee
I am going to install new gaskets on the baffle plate to exhaust and cylinder block to baffle plate.. Should I use some type of gasket cement also need to install the gasket to the bottom cowl. I am not a mechanic what else do I need to know to apply these gaskets. When I put the bolts in do I need to put any thing on them first. When I removed the bolts I broke 3 of them, had to drill out and I taped one with a 6mm tap.
Thinks for the information
Pete
Pete
