Re: Installing new steering wheel
Pictures would probably help, that being said...
most teleflex steering wheels simply slide down on a cone shaped shaft for the helm, and use a woodruff key to secure the wheel from spinning on the shaft, then a nut to hold it on....
If thats what your old system is, then you are ok, you may have to use your old nut though because threads/diameter may be different...
