Installing oil pressure and water temp gauges on a 2004 F115TLRC
Old Crow
I have a 2004 Yamaha F115TLRC
I would like to install electric oil pressure and water temprature gauges.
Is there a good spot to install the sending units?
I have fould the OEM low oil pressure sencor. I'm thinking I could put a tee there for the oil pressure gauge.
What about the water temp sencor?
Re: Installing oil pressure and water temp gauges on a 2004 F115TLRC
The engine is going to tell you when you have an oil pressure, overheat or other problems. I would not recommend adding any jury rigged type of valve. The only thing you should want to put in would be a block water pressure gauge. If you really want it, COMMANDLINKtm
Old Crow
I don't plan on jerry riging anything.
I'm hoping there is some port in the block already that I remove a plug and install a sending unit.
I don't want to tie into the Yamaha system at all, just install two stand alone gauges
Option 2-what is this Commandlink
It is the CAN bus circuit of Yamaha lets you see practically everything what the ECM sees, similar to Smart Craft, I Command, I am sure Suzuki and Honda have one as well.
