installing reeds in 1986 evinrude 140
dcolpitts
I'm installing boysen reed in my 140, I also can't find my instructions that came witn them. I know to jet the idle air jet 5 sizes smaller to richen the circiut, but on the base of the reeds are a strip of metal, does this sit against the reed body or against the metal plate that holds the reeds to the cage.
OBJ
Re: installing reeds in 1986 evinrude 140
Against the reed body. Have you worked the reed cages flat so the reeds will set dead flat against the reed cages? This is a very important step in the installation.
dcolpitts
thanks for the info OBJ, yes I have worked the reed cages flat with a wet sand paper on a sheet of glass. Thanks for the response
dcolpitts
another stupid question,the reed kit came with 8 bars to fasten the reeds to the body. Do I need to reinstall reed stpos or are these bars the stops. Sorry for the questions, it s---- to lose the directions.
OBJ
Use the bars that came with the reeds. Also, try and get the reeds centered over the reed cage ports.
Dhadley
The bars are called "rev plates(???)". Do NOT reinstall the reed stops. <br /><br />The bars may have a sharp side. We try to install those away from the fiber reed. Probably not necessary but...
dcolpitts
thanks OBJ, Dhadley, I thought so just checking. I'll let you khow the results. thanks again for thr help
Dhadley
Anytime!<br /><br />Looking forward to your impression of the reeds.
Basscat 1
Boysen reeds are the best investment I made with my outboard.<br />I am sure you wont be disappointed, especially with the idle to midrange.<br />One other small tidbit. Dont forget to lock-tite the screws that hold the reeds.<br />Good luck.
