Installing rule livewell pump
tab4593
I may have posted this in the wrong thread earlier. I am installing a rule livewell pump and it requires a 1" hole. The pump comes with a gasket for inside the boat and a washer for the outside. I will also be installing a rule strainer.
Should i use some type of water sealant around the whole to help keep moisture out?
Bob_VT
Re: Installing rule livewell pump
I would use some 3m4200 just in case it has to be removed in the future.
