shackle101
- Joined
- Jan 11, 2012
- 140
Hello all, so I'm trying to figure out a way to install a sky pylon on the back of my 2008 Tahoe 215. The problem is you can't really access the underside of the bolts to get nuts on the mounting hardware. Is there any way around this and still have the similar amount of strength?
I know these boats can come with factory installed waketowers. I was curious about the setup process if anyone has done that on these boats. Accessing the backside of the bolts seems like it would be an issue as well unless you cut the fiberglass. I was thinking maybe steel anchors might work, but not sure.
