Starting my Smart Tab SX installation. I had a concern about the 2010 Q7i because the transom is curved if installed "wide". Just did a test mount by assembling the lower mourning bracket and tab. The mounting bracket has a slight bend when pivot action tested 5" in from outside edge of transom as suggested, and there is an ever so slight difference in pivot action (stiffer) than if mounted 9" in from outside edge of transom. When mounted 9" in from outside edge of transom, there is no notable difference than when tested on a completely flat surface. So I will be mounting mine 9" in from outside edge of transom. Will take pics and post when done.
