Re: installing speakers in molded fiberglass
The old wood working trick is to apply masking tape where you will be cutting to control splintering from the saw. Never tried it on fiberglass, but it may work. And if it doesn't, like it was already mentioned, the speaker grills will hide the ragged edges. Put tape where you want the speakers, then mark the holes on the tape, then cut right through the tape. This has the added advantage of the tape being easier to make your cut lines on.
