Installing water pressure guage?
baxter66
I have 97 150 ocean runner where do hook up the pressure line to feed the guage.
ezeke
Re: Installing water pressure guage?
http://www.teleflexmarine.com/gauges-us/
Once you are in, if the black bar appears, click "Remove This Frame" in the black bar.
Then navigate to Trouble shooting and scroll down to Outboard Water Pressure on the right side.
I think that you are supposed to use the 60 PSI unit on your 1997 150 motor if you connect it according to their directions.
baxter66
I got a 60 psi gauge from ebay it came with a gauge cluster that had tach,volt,trim,fuel and water pressure. This is the last gauge i need to install on my boat.I just could not see how it hooked up to the engine.Thanks
