2001 CC Polar 21'
Any idea where the horn on this thing is? I can't find it, and am not sure where or what to look for, I have a broken horn button with no wires and before just buying a horn to wire it, I want to make sure it's not hidden somewhere- It's not on the outside of the console as expected; but I'm not sure where else to look.
Also, for restoring my instrument cluster, Tach and Speedo disconnected atm,- do you have any suggestions for restoring those? Anything strong than contact cleaner to repair the backs of the clusters? I assume, being the previous owner left gaping open holes in the console, that they may only need a good solid cleaning- atm, no current passes through the console other than the separate wired console lighting - which i was also planning on rewiring.
If not, does anyone know where I can find a nice full cluster of working instruments for the Yahama OX66? It would be cool to find a turnkey panel that I can simply connect to the motor, drill it in, and run with it.
Thanks in advance!
Thanks in advance!
