Question is this, sprayed in low density foam or rigid pink insulation?
Here is the situation in point form, sort of long, but the question still remains the same.
-Rebuilding 1978 Strarcraft Mariner 18'
-Went to a boat show, showed pics of the boat and explained my plains to several salesman. I figured with a new motor I would spend more time of the water and have less hassles. So I purchased NEW 115 Etec.
-I've talked to the shop over the summer, again discussing my plans for boat in order to have it ready to mount the motor. One of his concerns was specifically the floatation, so I explained how I was going to accomodate it by using the rigid insulation, the pink kind.
So I am at the point to re-install the floatation, so I go to get a measuremnt for the steering cable so I can install it prior to installing the floatation and the floor. I figured that he can install the motor after I have finished installing the floor.
At this point he asks how I was going to deal with the floatation issue, I repeated the fact that I was going to use the rigid insulation, the pink kind. At this point he proceeds to tell me I CAN'T use rigid insulation
So besides the fact that I am totally mad at the guy directing me in the direction of the motor, I am not sure which way to go. Sprayed in low density closed foam or the rigid insulation (pink).
Any thoughts would be greatly appreciated.:facepalm:
Thanks in advance
Regards
Wayne
