Intake gasket
elite222
Can anyone tell me if there is a difference between an automotive and a marine intake gasket for a 87 Merc 260hp?
tommays
Re: Intake gasket
anywere that comes into contact with water should be replaced with a marine grade gasket <br /><br />i would not try to use a automotive gasket anywere on my boat unless there was no other choise<br /><br />tommays
KaGee
Re: Intake gasket
Elite... I doubt you have much saltwater in Nebraska. Gaskets are not as critical in freshwater IMHO.
Dunaruna
Re: Intake gasket
Freshwater cooled - coolant is coolant, it incorporates rust inhibitors.<br /><br />Raw water cooled - Salt or fresh water doesn't matter, no rust or corrosion inhibitors although salt water is far more corrosive.<br /><br />Aldo
Re: Intake gasket
Just use a Quality Gasket set....<br />Like Fel-Pros.....
f_inscreenname
Re: Intake gasket
Ditto Bondo<br />I use Fel-pro from local auto parts store. I also have had a motor apart after years of use and found no problem with gaskets. All were raw water cooled.
prockvoan
Re: Intake gasket
If the engine is raw water cooled,the only marine gasket needed would be the head gasket.
