Re: Intake swapping?? 4.3l omc
Well, one thing, Is the donor engine a marine engine? If yes.. then if the 4 barrel is in good shape.. you can use it... if it is not a marine engine.. then no, its dangerous to use it..
One concern is HP vs gas economy.. You will see a slight increase in HP like Bond-o said.. but you will also see a dramatic increase in fuel usage.. so, if the boat performs well, and can get up on plain and runs nice with the 2 barrel, it would probably be to your advantage to not use the 4 barrel... but, if you can use the extra HP - go for it...
