interchange chart
57lawney
was reading post from april 24 2010, on intrechange chart on l/u . what changed from 92 to 93 on 40 hp l/u that would change that the two wouldnt interchange?
trendsetter240
Re: interchange chart
The drive shaft is different so you can't simply bolt on a 1992 LU to a 1993 powerhead or vice-versa.
57lawney
Thanks trendsetter, a friend has a92 lu , very reasonable, so will have to pass,tks for info
bob johnson
can the drive shafts be switched???
I realize it would involved takign the LU apart...but is it just a spline end change at the power head?????
would the case fit?
bob
bob johnson
Yeh its there, direct link.:)
Lower interchange FAQ file.
http://forums.iboats.com/showthread.php?t=359907
this is what i get:
You are trying to access a page that is no longer valid or does not exist.
if you have found this page via a search engine, please note that we are working to prevent this, and get them to properly index our new site.
if you arrived at this page via a bookmark or favorites link, please update your bookmarks.
the URL for the iboats forums is http://forums.iboats.com.
The New Url for what you seem to be trying to get to is
I think the link you are giving is a STICKY called SECRET FILES.
when i saw FAQ that is what i clicked..and it is a dead link..
FAQ is the header just to the right of your USER CP header...
bob
jonesg
wow yeh dead link.
Need some housecleaning around here.;)
